Posted by RustyFarmall on September 17, 2007 at 11:23:10 from (66.43.253.55):
In Reply to: M carb: rebuild? posted by e-manhunt on September 17, 2007 at 11:07:08:
There are two different models of carbs, one is for a distillate/kerosene engine, and the other model is for the gasoline engine. The only real difference in these carbs is the fact that the distillate carb has the drain-cock in the bowl, and the gasoline carb has a pipe plug. There MAY have been some other differences internally, but since distillate fuel has not been available for about 40 years now, virtually ALL of those carbs have been rebuilt using the gasoline parts, and to make a long story short, there is NO DIFFERENCE in any of them now. One will interchange with the other, even the internal parts will interchange from one to the other.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
