Re: Electrical Grounding
Posted by John T on September 17, 2007 at 14:01:27 from (66.244.83.147):
In Reply to: Re: Electrical Grounding posted by Fromjb2 on September 17, 2007 at 13:00:28:
Its been yearsssssss since I designed power distribution for a computer room but rememebr those isolation transformers are indeed considered "seperately derived sources" from which the Neutral got bonded to all sorts of grounding electrodes (earth ground rods werent available DUH) such as building steel n pipes and the raised floor skeleton steel n all other sorts of metallic objects in an attempt to keep all at one single common ground reference n avoid ground loops.
John T
