OK, Thanks. That makes sense now. I had replaced the top seal in the hand pump under the steering wheel and had removed the dash panel to remove the hand pump. When I put it back together, there was a thick round rubber disk (like gasket material) that went under the throttle control. Since I wasn't sure if the seal would fix the leak and since I wasn't sure where to align the throttle handle on the shaft, I just stuck it on and only tightened the nut a little since I thought I might have to pull it off again. It took a little heat to come off the first time.
On another note, the parts guy had me remove the steering hand pump to order the right parts. After I got the parts, I found out the top seal could be replaced by only removing the steering wheel and leaving the pump unit installed. Live & learn I guess.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
