Re: stupid motor
Posted by Brownie450 on September 17, 2007 at 17:13:18 from (207.177.82.54):
In Reply to: stupid motor posted by smdv806 on September 16, 2007 at 19:01:59:
Can't remember if there is a roll pin or straight pin in the drive gear on this distributor. Have you had the distributor out to look at the drive end? If there is a roll pin, It might have enough slop in the gear & shaft to cause timing problems. Unlikely, but worth a look.
