Posted by K.B.-826 on September 17, 2007 at 21:01:04 from (24.180.149.94):
In Reply to: 1206D Gearshift posted by Kelly Boesen on September 17, 2007 at 20:44:39:
The inside lever shifts the ranges. You have three ranges- HI, LO, and R (reverse), with neutral located between LO and R. The outside lever shifts the speed gears- 1, 2, 3, and 4. Of the forward gears, LO 1 is the slowest, with HI 4 being the fastest. You can use any of the four speeds in any range, even reverse. You may also have a lever to the left side of the steering column, which controls the TA. The TA was the optional powershift, meaning it can be shifted on the go, under load, without touching the clutch pedal, giving you two speeds in every gear, for a total of 16 speeds forward and 8 reverse. When the TA lever is ahead, it is in direct drive, and when it is pulled back, it will be in underdrive (slower). Check with your friend before trying the TA, because many times the low side will be out on these older tractors.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
