If you do not have a blind hole bearing puller, here are two other methods you can try.
Find a shaft that is a close fit inside the bushing. Fill the cavity behind, and the bushing, with grease. Start the shaft into the bushing and give it few whacks with a hammer. You may need to add more grease as the bushing starts coming out.
If the bushing is worn too much to get a good fit on a chunck of shaft, get a tap that will thread into the bushing and screw that in until it bottoms out. Keep turning and the bushing should be forced out.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
