Re: Farmall 400 Not Starting
Posted by old on September 18, 2007 at 07:46:00 from (4.244.222.174):
In Reply to: Re: Farmall 400 Not Starting posted by Lance_MF_180 on September 18, 2007 at 07:19:47:
To add to what rusty said. After doing what he said pull the carb drain plug and check for gas flow there also. If no flow try tapping the carb some it maybe a simple stuck float/needle which tapping may pop loose. Carbs aren't all that bad to rebuild but you do need some carb cleaner to soak the carb in over night and a good kit to put back into it. A good kit will have instructions on how to do the job
