Re: 806 diesel noise
Posted by ddg on September 18, 2007 at 12:33:33 from (205.188.116.73):
In Reply to: Re: 806 diesel noise posted by Thomas B on September 17, 2007 at 19:40:29:
I have a 97 Dodge/Cummins pickup with 300k miles on it. It started making a taping noise like that. The fuel lift pump (not the injector pump) has a primer knob on it to full the fuel system after you change the filter. If I hold my thumb on that primer knob, the clicking goes away. so I"ve decided its a weak spring in the lift pump, and it can"t follow the cam lobe properly, and makes that noise. Under load, it goes away, it just does it under light fuel demand or at idle.
