Re: towing capacity of a Farmall A
Posted by K.B.-826 on September 18, 2007 at 21:03:46 from (24.180.130.36):
In Reply to: towing capacity of a Farmall A posted by George22 on September 18, 2007 at 19:02:09:
I think the general rule for modern-day tractors towing trailer-type implements is that the weight of the implement should not exeed 1.5 times the weight of the tractor. I'd stay a little lower than that for the A. Keep in mind that having enough power to pull the implement is the easy part, controling the implement is the hard part. Gotta have enough weight so that you don't get pushed aroud, and enough brakes to safely stop. Like what was said below, be careful pulling those trees around, take it slow!
