Re: Needle valve for D-10 carb
Posted by RustyFarmall on September 19, 2007 at 04:37:59 from (66.43.253.55):
In Reply to: Needle valve for D-10 carb posted by Mike CA on September 18, 2007 at 20:25:28:
Mike, do yourself a favor and do a complete rebuild on that carb. There is rust and crud hiding in there that won't come out by simply soaking it in cleaner. If the tractor had been a running tractor you might get by with those shortcuts but since it has been just sitting for awhile you are going to have problems. Trying to re-use old gaskets is asking for trouble.
