Re: towing capacity of a Farmall A
Posted by Janicholson on September 19, 2007 at 06:25:27 from (199.17.6.122):
In Reply to: towing capacity of a Farmall A posted by George22 on September 18, 2007 at 19:02:09:
Interesting topic!
An item not mentioned, that is very important is not the weight of the object, and not its friction component, but the force on the attachment to the tractor, and the dynamics of that force in relation to the axles, center of gravety, and traction. Stretching (tensile) loads on really big articulated tractors often exceed their weight by as much as 10 to 15%. this assumes wheel slippage enough to get a large contact patch along the bottom of as many as 12 tires, with ballast in experience based positions to allow 50/50 split of pull from front and from back. The Big Bud 735 (the only one) can pull tensile forces at the 65,000 pound level (best of my memory from 9 years ago) Normal cultivation was with a 60 foot field cultivator at 8 mph at about 8" in medium soil (Montana)
If you drag a fair number of logs, build a mini skidding trailer (kind of like a propane tank hauler) to lift the fronts while pulling.
Always keep the attachment point low. Never chain to castings. Always pull from the center of the width of the tractor. Figure out where the tractor will go, and how fast, when the chain comes off the load.
Your tractor is probably a 123 now (as pointed out) making more HP and it is fresh. Safety first. JimN
