Re: towing capacity of a Farmall A
Posted by Harold H on September 19, 2007 at 07:12:39 from (69.40.73.80):
In Reply to: towing capacity of a Farmall A posted by George22 on September 18, 2007 at 19:02:09:
In Nebraska test 329 of Farmall A gasoline in 1939 the maximum pounds pulled was 2387 pounds at 1.93 mph. I cannot find Nebraska Test for Super A. However, Nebraska test 537 of Farmall 100 (basicly same as Super A) in 1955 the maximum pounds pulled was 2305 pounds at 2.36 mph. A little less pounds but a little faster. As you can see both are basicly the same. Depending on weights and tires, you should not be able to tell the difference in an A and Super A.
Harold H
