phillip w. said: I did have the steering shaft out of it to replace the radiator, did I put something together wrong?
Check the U-joint. Where that bolts together there should be a washer in between each section of U-joint. That washer slides into a slot on the top of the lower shaft that acts as a woodruff key. It sounds like you didn't put that washer in there, and the upper shaft is just spinning until it catches something on the lower shaft to turn the wheels.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
