Re: More Sleeve Issues
Posted by Janicholson on September 19, 2007 at 18:13:14 from (66.173.50.150):
In Reply to: More Sleeve Issues posted by Uncle Fester on September 19, 2007 at 16:36:23:
A sleeve puller will for sure take it out. The sleeve may be defective. Measuring it will provide that answer. If it were flush I would not worry But recessed is (in my mind) problematic. If you measure the rim and it has axial runout, either get a different one (if time will allow) or shim it as you described and go with it. JimN
