Re: How to tighten farmall h steering?
Posted by TomH in PA on September 19, 2007 at 18:59:30 from (69.138.21.5):
In Reply to: How to tighten farmall h steering? posted by phillip w. on September 19, 2007 at 17:50:22:
There"s a castle nut inside the steering box that keeps the shaft from moving forward or backward when you turn the steering wheel. It can be adjusted to take a lot of the slop out of the steering. Have someone turn the steering wheel while you watch how things move and you"ll see how to tighten it.
