Re: 1954 Super H Starter Rod
Posted by Gauger on September 19, 2007 at 19:02:37 from (4.252.157.224):
In Reply to: 1954 Super H Starter Rod posted by Brian Schmidt on September 19, 2007 at 18:46:38:
The material is 1/4" round. The bends at each end are 7'16" inside dimension and go in opposite directions. Center to center is 25.5". There are some slight bends that you will have to make as you go.
