The two springs hold the impeller shaft forward so that it does not rub on the back side of the impeller. The water pump has two ball bearings that support the pulley but, unlike modern pumps, the impeller shaft is carried on a brass sleeve type bearing. That is why there are two grease zerks. On lubes the two ball bearings. The other lubes the impeller shaft bushing. If you over grease the bushing the excess is forced into the coolant. If you do not grease it, the coolant will get in between the shaft and bushing and cause corrosion and rapid wear. Missing or broken springs will also allow the coolant to replace the grease more quickly.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
