Re: IHC 504 PTO
Posted by MN Mike on September 20, 2007 at 07:16:29 from (216.77.154.39):
In Reply to: IHC 504 PTO posted by cdv on September 19, 2007 at 19:16:40:
I think your 504 is the same style as my 340. Looking at the PTO, there should be a cover on the top right of the PTO held down by a screw. If you get that cover off, there are two screw/nut combos under there. the one towards the front of the tractor should control the engage and the rear should control the PTO brake. Loosen the nut and turn the screw in to tighten the band. retighten the nut to hold the screw in place when you're done.
If that isn't it, someone please correct me!
