1) Bring #1 to top of compression stroke. 2) Line up timing mark on flywheel. 3) Magneto; Turn mag counterclockwise slowly just until the impulse releases and lock it down right there. Distributor; With ignition on put volt meter from distributor side of coil to ground - you should be reading no voltage. Turn the distributor slowly counterclockwise until you read battery voltage indicating the points have broken. Lock it down right there.
This is static method of timing. Don't let anyone talk you into dynamic timing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
