Replaced the left side brake shaft seals on my M earlier this spring... Both were CR seals in CNH packaging... Price was steep. Takes 2 seals per side as the new ones are thin, single lip seals.
Existing leather seals are a real PITA to remove. Get a GOOD seal puller or drill and run a sheet metal screw in and get a slide hammer on it. Real estate is tight. You can't remove the carrier housing to make it easier without first getting inside of the rearend housing to get the gear out of the way. You'll break the housing if you do not.
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
