The generator could find a ground through that bolt, but the fixed mount is usually the primary path, and the bolt would likely only hold the bracket to the WP grounding at the casting. The bolt is corroded (probably) by leaking coolant/water that got into the bolt hole at the pump block interface, and filled the hole around the bolt with dried out components of antifreeze. Still a tough removal. Good luck, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
