Posted by Owen Aaland on September 21, 2007 at 00:17:45 from (65.174.247.81):
In Reply to: H Overcharging posted by MarkOhio on September 20, 2007 at 23:53:01:
A field winding shorted to ground at the F terminal of the generator will act the same as if the light switch is in the high charge position.
Remove the band covering the brushes. Two of the brushed are 180 degrees apart from each other. These are the brushes that carry the charging current. The third brush (may be adjustable but later ones were not) is attached to one end of the field coils. The F teminal is the other end. With the third brush held away from the armature there should be no continuity to ground at the F terminal.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
