Re: H Overcharging
Posted by Bob M on September 21, 2007 at 04:21:18 from (151.190.254.108):
In Reply to: Re: H Overcharging posted by MarkOhio on September 21, 2007 at 00:02:05:
Mark - As Owen mentions an internal short in the generator field winding will cause overcharging. So also will a short to ground in the wire running from the generator F terminal to the light switch, or a short in the light switch.
Suggest disconnecting the wire from the genny F terminal then running the engine. If it still charges hard the problem's internal to the generator. However if the ammeter shows no charge with the field wire disconnected it means there's a problem with the wiring or the light switch.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
