Posted by John T on September 21, 2007 at 07:38:06 from (66.244.83.147):
In Reply to: H Overcharging posted by MarkOhio on September 20, 2007 at 23:53:01:
Whether or not it can still charge with an internal Field ground short depends on where the short is located. One suspect (unless its a winding to pole piece short) is where the 2 field windings splice and another chance where the last winding goes to the Fld post. Based on what you say UNLESS theres a short in the wire from the gennys Field to the Light switch (Bobs suggested unhook the wire test will quickly show that) it must be shorted somewhere electrically near the connection to the gennys Fld post.
If its a three brush genny one can relocate the third brush for a lesser rate charge also.
If you remove all the gennys external wiring connections an ohm meter might tell something. With one lead to case/frame and probe the other, Id expect very low ohms on the Arm post (if brushes n arm all okay) and maybe around 1.5 to 3 ohms on the Field post. If the Field shows around 0 Id look for an internal short close to where the field winding wires to the Field post and/or suspect a short in the pass thru stud insulator right at the Fld post. Come to think of it if she always charges at max rate and theres NOT an external wiring short to the light switch, a short where the Field post passes through the gennys case IS A PRIME SUSPECT.......
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
