Posted by Michele Bush on September 22, 2007 at 05:47:36 from (76.235.32.70):
Hi, K.B., You seem pretty knowledgeable about Farmall tractors, I hope that you can help me out--I have a Model F756D serial# 13351 S-Y tractor that is leaking fuel from the pump, specifically from around the plate just to the right of the gear housing. My father-in -law tried to remove the plate, but it won't remove easily. I suspect a gasket, but he's afraid to pry on the cover because it's small (about 2" tall) and kind of thin. He asked me to research the fuel pump and see if I can get an exploded view of the fuel pump itself, and maybe some instructions too, if it's an involved process. Thanks for any help you can give us--Michele B.
quote="K.B.-826"](quoted from post at 04:15:03 07/26/07) IH changed their serial number format around '69 or '70. They quit using the model number suffix letters, and added a bunch of coding in front of the actual serial number. You will not find the "D" for diesel, the "S" for TA, or the "Y" for 12 gpm hyd pump on these later tags as you commonly would on an early model. What does your serial number line read? If it starts out something like 200 and has the letter "U" (for United States built) right before the actual serial number, you've got the late serial number format.[/quote]
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
