Sure: With everything connected and the tractor running with battery charged, Use a jumper wire to ground the field lead (smaller)of the generator to a clean bright spot on the tractor. The Amp gauge should go up in the charge direction about 8 to 10 amps. This tests the generator output. If it only goes to zero, or a bit above, the generator may need to be checked.
If it charges when jumped as above, the possible problem might be the Voltage regulator. Use the Search for box above and put in John T trouble shooting in the box. Good stuff. Wiring diagrams are found in the link below supplied by Bob M They are also awesome, Keep us informed of the progress, many times we do not know if we help the person because they never let us know the outcome. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
