Re: W450 Gas Splash out of Air Intake
Posted by Janicholson on September 22, 2007 at 17:04:22 from (66.173.50.147):
In Reply to: W450 Gas Splash out of Air Intake posted by Brian Jensen on September 22, 2007 at 12:39:42:
It means it is flooded very seriously.
Rule 1 always shut off the fuel at the tank when not running it, even 10 minutes.
Rule 2 See rule 1
If you take off the air intake hose an dry things out, things will be better. If there is fuel in the oilbath aircleaner, the whole thing needs to be serviced.
If it floods anf fuel runs out the carb intake when the fuel valve is opened, the needle and seat in the carb's float bowl are stuck open, or have junk under them.
Make sure the plug firing order is correct 1342, and (usually starts top right and goes clockwise around the cap) Keep us informed JimN
