What you need to watch to avoid burning valves in those IH gas engines is the ash content of the oil. You need to be using an oil with an ash content of 1/2 percent or less.
The problem with the exhaust valves comes from the valve stems getting a layer of carbon buildup on them. This is not a problem as long as the load is kept constant on the engine but when you go to pull it hard the valves will get hotter and the stems expand. The carbon buildup then causing the valve to stick as little. When the valve sticks open under heavy load the combustion gasses leaking past the seat will cut them almost like a cutting torch. The low ash oil will not entirely eliminate the problem but it does greatly reduce it.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
