Posted by IndianaRed on September 23, 2007 at 09:02:49 from (75.51.224.118):
Hey Guys,
Need some help again. Just got up the nerve to go take the clutch shaft out and look at the clucth. I had run the motor with the shaft not completely connected, just one bolt in actually. Broke the piece that bolts up to the top of the housing that holds the shaft/throwout and the sleeve. Got new ones, put them in, though I was ok. Drove her for about 15 minutes and started feeling a little rattle underneath as I let clutch out. Got home and shaft was not rotating smoothly and looked like the clutch as not either. The center where that shaft goes through is off kilter. Grandad thought it had to be the shaft being bent, but I took it out and ran it and looked up inside and can see it"s not rotating right even without the shaft. The flywheel is good and turning smooth, and the plate looks ok, just the center seems to be wobbling.
Any ideas on what I"ve done and what I might need to do to fix it?
When I ran it without the shaft in right, the shaft swung out to the outside as it rotated on one bolt making a big circle around the piece it connects to going into the transmission.
As you can imagine I"m feeling pretty stupid about now.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
