Re: Farmall H manifold switch,,,,,,,,,,,,,,,
Posted by Janicholson on September 24, 2007 at 06:39:20 from (199.17.6.122):
In Reply to: Farmall H manifold switch,,,,,,,,,,,,,,, posted by Bernsy MN on September 24, 2007 at 05:46:19:
Electrolysis to get the rust out, then a 2" npt tap to recreat new threads. Then Moly anti sieze to keep it removable. As Andy says someone might need that other manifold. It will probably run a hotter manifold with the Distillate reducing power a tiny bit, but improving vaporization. It will need the damper in it if you use it or it will over heat gasoline. JimN
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
