F12 Point of Information
Posted by James Williams on September 24, 2007 at 13:06:45 from (65.73.216.11):
We had our first tractor ride saturday only 7 tractors showed up,but thats ok,its a start.I drove my trustworthy F12,It started the first crank,but when I pulled the choke off it cut off,We keep playing with it and finally keep running,mostly with the choke on.I figured carb.problem,so I took the carb. off and cleaned it good,reinstalled,it than nothing. I removed all of the new gas lines and blew them out,and found nothing.I made a nurse tank and gravity line to the carb. and it ran.Only thing left is the fuel pump,I removed the line between the carb. and the tank and it was only a minium of gas.I said all of this to say just becaues a motor runs with the choke on it doesnt always mean carb.problems,I think the choke was sucking the gas out of the lines
jimmy
