Re: New Carb
Posted by RustyFarmall on September 25, 2007 at 14:30:55 from (66.43.253.55):
In Reply to: New Carb posted by TreySoTex on September 25, 2007 at 13:27:30:
Read the instruction sheet that came with it. I'm betting that it should be pretty much dialed in at the factory, with only a few minor adjustments necessary after the tractor has warmed up a bit. The idle mixture screw and the idle speed should be the only two things that will need tweaking.
