Take the hose off of the intake to the new carb. Put it in Neutral, and set brakes/block tires. Have someone crank it to try to start it with your hand (palm) over the intake. (two or three revolutions) There should be a serious suction that pulls pretty hard on your palm. This will (should be) the same as a perfect full choke action. When you pull your palm away it should leak a little gas out of the carb intake. If so there is something else wrong. (Ignition) If it does not pull hard, there may be a intake leak in the intake manifold, Or the timing gears/system is not right. If it pulls on your hand, but no fuel, it is not getting any fuel from the tank. Good luck with diagnosis. JimN
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
