Re: PTO install
Posted by K.B.-826 on September 25, 2007 at 22:29:40 from (68.115.99.119):
In Reply to: Re: PTO install posted by powderhombre on September 25, 2007 at 17:46:28:
Yes, PTO was an option. If your tractor has the straight 4-speed trans, it should just be a matter of installing the extension shaft, shift tube, and the PTO unit. Farmall C, Super C, 200, 230, and 240 parts should work. If you've got the 4-speed with high and low range, it's gonna be a little different ballgame, as I beleive those models used a different set-up that was probably unique. With enough time and money this can be done, get yourself a parts book.
