Re: Shifter
Posted by Andy Martin on September 26, 2007 at 15:47:44 from (63.123.95.201):
In Reply to: Shifter posted by Overall Bill on September 26, 2007 at 15:06:10:
Soft plugs on each side of the shifter pedestal have to come out. Then there is a floating horizontal shaft (may have a groove worn in it) which comes out. You may have to push down on the shifter to get the shaft out. Then the shifter comes right out and you can use a long screwdriver to align the rails.
If it is a persistent problem you often can fix it by welding up the bottom of the shifter a little, but you also can keep it from happening just by paying attention to how you shift to make sure you get into neutral before going to another gear.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
