Re: farmall f 20 pulling tractor
Posted by Len Rahilly on September 27, 2007 at 13:50:18 from (75.69.99.42):
In Reply to: farmall f 20 pulling tractor posted by Chris Farmallf20 on September 25, 2007 at 21:31:38:
I can dig up written info on the governor and timing, and will be glad to repro it and send. Don't get good results scanning, so would use snail mail.
You probably know there were 2 governors used, and their adjustments are different. The original governor was not "variable," which means that it doesn't do much governing if you throttle back. Sometime toward the end of production--1937, I think--IHC went over to a "variable" governor, which governs throughout much of the speed range of the engine. This is the governor with the notched rod left of the gas tank. There were several companies that produced aftermarket variable governors, too, but their control rods or levers look somewhat different. IHC also made a kit to replace the original governor, but its control rod was on the right (I used to own one of these).
Most of the F-20s I have seen in recent years have had the original (kerosene) manifold replaced, after the original burned through. You can spot the difference immediately. The kerosene manifold has an enormous heating area around the middle, to keep the fuel hot for good vaporization. A gasoline retrofit manifold does not have this big heating area, AND there is no lever to switch from hot to cold. The original manifold had a lever that you used to switch to "cold" for running gasoline.
