Re: The H and M down by the lake PIC
Posted by Bob Kerr on September 27, 2007 at 20:04:59 from (205.188.116.73):
In Reply to: Re: The H and M down by the lake PIC posted by Mike CA on September 27, 2007 at 11:28:38:
Hehehehe! A farmall submarine! I better put on exhaust and air pipe extensions! Luckily it is the shallow end of the lake, you can walk way out from that side. The other side is the one that has the door to davys place! You only get three steps in and over your head. There is a brand new only used once for 15 min, trolling motor on that side that is Davys now. Not mine, I use oars, they float! Guy forgot to tighten up the mounting screws all the way and off it went!
