Re: Loading logs old school way! pic
Posted by Bob Kerr on September 27, 2007 at 20:29:58 from (205.188.116.73):
In Reply to: Re: Loading logs old school way! pic posted by old timer on September 27, 2007 at 14:28:01:
Ash is what his customer wants. All I can tell you is it is light and strong and less likely to split when driven than pine. different woods have better uses than others. My A frame I load logs with is made from poplar for bug resistance, light weight when dry, and is pegged together at the top with a 1"locust peg which is tough stuff.
