Re: Still no starting on the B....
Posted by El Toro on September 28, 2007 at 04:01:13 from (205.188.116.73):
In Reply to: Still no starting on the B.... posted by TreySoTex on September 27, 2007 at 20:48:57:
You need to clean the points with a piece of 320 wet or dry then use a cotton swab dipped in alcohol to clean them again. You need to clean that mess inside the mag too. I think the FM mag's points are set at .015." Then see if there's fire at your sparkplugs. Make sure the kill switch on the mag is in the run position. Hal
PS: If you ever need to pull the mag you need to
look at the rotor and see where it is pointing, then make a sketch. Then don't move the engine once the mag is removed. When reinstalling the mag or any mag you turn the rotor to the position
you have in your sketch and install the mag. The same applies to a distributor too.
