Re: 1941 Farmall A engine
Posted by El Toro on September 28, 2007 at 14:57:25 from (64.12.116.73):
In Reply to: 1941 Farmall A engine posted by Toby Maxwell on September 28, 2007 at 13:51:30:
You can buy a shortblock rebuilt from www.farmerlink.com. You may be able to find a good used C113 or C123 block and completely rebuild the block using your old crankshaft and cam. The crankshaft should be measured for wear at your auto machine shop. Have the head redone too. I would install a new sleeve and piston kit
too. Then with good care and maintenance your engine should go another 50 years. Those engines were used in lot of IH tractors so there should
plenty of blocks. They were used in some of IH combines too, along with the C135 engine. I think it will fit the Farmall A too. Hal
