Re: mw handcluch
Posted by randy hall on September 28, 2007 at 16:59:08 from (209.143.0.64):
In Reply to: mw handcluch posted by preacher#77 on September 28, 2007 at 14:13:23:
the pinion shaft for the super m kit is different and there is an adapter plate to mount the housing on a super m.you will have to get a band brake assembly from an m because that is what was used buy m+w, so in a nutshell a unit off of a straight m will not be able to be used on a super m.
