Sandblast them or sand them by hand, or use a fiber wheel on an electric drill. If rust is still in the pits use Picklex 20 or a similar cheaper product from Home Depot called Must for Rust, or some other protectant/converter. Those will convert or neutralize the rust. Then use body filler in the pits, sand smooth and prime with epoxy primer followed by a sandable surfacer. The epoxy gives a good bond to the metal, it is also waterproof. The sandable surfacer will fill any scratches caused by the other sanding procedure and leave a smooth surface to be top coated. Etch primer, although it can be used on old metal is not necessary because you have done the etching by sanding. Etch is mainly used by body shops on new metal that they do not wish to take the time to sand. Epoxy is the way to go. For the pieces you described it is the best primer there is.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
