You need to remove a plug on the bottom of the carburetor. Hold a clean container under the carb. and see if there's a full flow of gas. If there isn't you need to remove the gas line at the carb and see if there's good flow of gas from the gas line. You may have dirt in the gas tank. Take a good flashlight and look in the tank for rust or dirt covering the outlet. There may be a screen at the carb inlet behind the gas inlet fitting that your fuel line is connected to. It could be blocking fuel if its full of rust or dirt. Hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
