Re: international 3414 3 pt hitch
Posted by Fromjb2 on September 29, 2007 at 18:37:55 from (74.111.119.222):
In Reply to: international 3414 3 pt hitch posted by keith smith on September 29, 2007 at 17:57:35:
Hi Keith, I believe the large plug that you pulled was where an aux remote outlet would be installed and there will be no flow there unless the isolating valve is closed. Isolating valve is controlled by the knob at your right hand on the hydraulic valve body below the front of the seat. When the isolating valve is closed the flow is diverted from the 3pt to the aux remote port and is still controlled by the 3pt lever but the 3pt hitch will not work. The left hand knob controls the flow rate to the 3pt, selects either 2.5 or 5 gpm to the 3pt.
I have a B414 Operator Manual that has a simple diagram of hydraulic flow.
If you email me at clarabrownlee@rogers.com, I can scan a couple pages for you.
JimB
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
