Re: Water in the Oil
Posted by J in Pa on September 30, 2007 at 19:15:01 from (24.239.59.159):
In Reply to: Water in the Oil posted by 3RD Generation IH on September 30, 2007 at 16:37:40:
3RD
had a similiar problem with an H.
i had overhauled it new sleeves pistons, etc etc.
after a couple days went and checked the drain in the pan. found anti freeze.
dropped the pan and started looking.
found it dripping between the block and the sleeve on #2 cylinder. somehow the block had a hole in it. not a crack but a hole.
must have been done before i got the tractor.
my suggestionis to drop the pan and start looking.
if yo have anti freeze in it you should be able to see where its coming from. anti freeze doesnt need a large crack or hole to get through.
good luck
J in Pa
