Re: Full Engine Rebuild or IN-Frame, How do I Know ?
Posted by Lee in Iowa on September 30, 2007 at 20:46:25 from (66.172.198.62):
In Reply to: Full Engine Rebuild or IN-Frame, How do I Know ? posted by ed8844 on September 30, 2007 at 12:41:05:
Good plan I have a 560 that needs cam bearings, sure wish it had been done when it only had an in frame a few years ago. Lee
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
