Re: Full Engine Rebuild or IN-Frame, How do I Know ?
Posted by Fromjb2 on September 30, 2007 at 21:21:03 from (74.111.119.222):
In Reply to: Re: Full Engine Rebuild or IN-Frame, How do I Know ? posted by ed8844 on September 30, 2007 at 18:59:01:
Ed, old IH mechanic would check blow by removing the crankcase oil dipstick with the engine under load and see how much smoke came out the dipstick tube. If tractor has been sitting for a long time could be stuck rings. Put some GM ATF in the Diesel fuel, that will cleanup everything.
The BD154 was a very good engine except tough to start in cold climates. Like I said we traded our B414D with 15K ours only to get a larger tractor for PTO work, not because of engine problems.
JimB
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
