When you were putting it back together, did you make sure that the tooth on the end of the governor to carb was engaged with the slot on the carburetor throttle shaft? I once put the carb on my H and did not have that put together properly and the tractor ran fast and would not go down. I pulled off the carb and made sure that the governor shaft tooth was engaged in the carburetor shaft slot (in the slot only) and it ran correctly.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
