Re: Water in the Oil
Posted by slowfolk on October 01, 2007 at 09:59:38 from (69.24.160.98):
In Reply to: Water in the Oil posted by 3RD Generation IH on September 30, 2007 at 16:37:40:
Had the same problem with a Allis Chalmers WD45.
I would check the oil on a regular basis and notice the the oil was coming up higher on the dipstick. After talking with others on this site I started removing the head first, nothing appeared wrong, then the pan, the first thing I seen was antifreeze dripping from around the sleeve on the rear piston sleeve. Removed that sleeve and found the orings from around the sleeves deterioated causing a leak.
Slowfolk
