Re: Full Engine Rebuild or IN-Frame, How do I Know ?
Posted by ed8844 on October 01, 2007 at 13:01:00 from (74.229.216.165):
In Reply to: Full Engine Rebuild or IN-Frame, How do I Know ? posted by ed8844 on September 30, 2007 at 12:41:05:
I sure am embarrassed for not doing a compression check right off the bat - Cranked the beast up today and pulled the dip stick partly out- Lt gray smoke same as out the valve cover vent - Pulled the dip all the way out and nearly got a face full of oil lots of pressure in there- Warmed it up good and shut it down -Cylinder 1 has 280 psi, #2 has 300, #3 has 220 and #4 has no compression at all, zilch - Oil has diesel fuel in it too .
I know what I'll be doing on my day off.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
